charcoal canister?????
Old Aug 10, 2001 | 03:27 PM
88greyiroc's Avatar
ok what is the charcoal canister where is it and how do i clean it?
Old Aug 10, 2001 | 04:33 PM
Synergy's Avatar
Never start a sentence with "ok"... LOL
First what kinda of car do you have ? A charcoal canister can't be "cleaned" and the filter can't be changed. You have to buy a whole new one from the dealer.
Old Aug 10, 2001 | 05:04 PM
SS-84's Avatar
Car: 1992 RS
Transmission: 700R-4 when it works
Ok ok ok
Why would I want to clean/replace the charcoal canister?
What would happen if it "weht bad"?
LOBC-- SS-84
92 RS Heritage package with a 305 3" high-flow cat and pipe with a Dynomax 3" in dual 2 1/2" out.
84 El camino- 383 CID, Performer RPM, GMPP vortec heads, Holley 750 D.P.(0-4779c), Crane Energizer 274,Dual 3" Flowmaster 40 Series Exhaust, Turbo 350 (375b), TCI 2500 stall, Richmond 3.42 gears, PST Poly graphite Suspension bushings, PST steering linkage, PST springs, Monte SS sway bays, Wheels from a Third gen(does that count?)
Old Aug 10, 2001 | 05:46 PM
88greyiroc's Avatar
i own a 1988 350 tpi iroc-z . Meanest car this side of the us border.
Old Aug 11, 2001 | 10:45 AM
Synergy's Avatar
Well if it's as mean as you say it is, it obviously wasn't you that made it that way. lol
Old Aug 11, 2001 | 11:14 AM
Vader's Avatar
88,
All joking aside, the EVAP canister (charcoal canister) is located at the front corner of the engine compartment. Unfortunately, anything newer than a 1987 doesn't have the breather filter pad on its underside and is basically unserviceable. If yours has become clogged with dust, you'll probably have to replace it.
If it is full of liquid fuel, however, the purge system is probably malfunctioning and not evacuating the canister of fuel when the engine is running.
Make sure the vacuum hoses are connected correctly according to the underhood VECI label. You also need to be certain the EVAP purge control solenoid and purge valve is working (located on top of the canister). This solenoid is controlled by the ECM and vacuum is ported from the throttle body. When above idle, there should be a varying vacuum at the inlet side of the solenoid. It may be a low vacuum, so you should check with a gauge if possible.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
[This message has been edited by Vader (edited August 11, 2001).]
Old Aug 16, 2001 | 03:12 AM
FiReBReTHa's Avatar
how much to replace?
91 FireBird 305 V-8
Edelbrock Catback, Fourth Gen Console. i have six cupholders. all for starbucks!
ghetto rigged cold air intake,
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
God Created The Earth, And Then Turned Up The Bass
Old Aug 16, 2001 | 08:51 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Vader, you said that the ECM controls it, since I am no longer running my ECM do I need this thing hooked up, because I only have one tube running into the canister right now.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 16, 2001 | 10:22 PM
88 GTA Notchback's Avatar
Mark,
FYI - you may want to check all of the hoses running to and from the unit. Mine were starting to rot and split. It really improved the idle of my car.
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT |88 Mustang GT
94? Impala (real close)|97 Dodge Neon
86 Corvette |2000 Prowler
88 ASC GTA | And a few more Accords and Neon's.
And more Civic's then I can count. Why do they even bother?
Quzyle
Oct 15, 2015 03:35 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
TBRays98
Sep 6, 2015 05:05 PM
