PLEASE HELP ME IDLE PROBLEM
Old Aug 15, 2001 | 06:14 PM
89Irocz23's Avatar
ok I need some help here!!! I have a 89 Iroc Z 350 TPI Well I just got the engine rebuild and when I start it the idle is way up to 1500 and it stays no matter what. Even when its warmed up it dont make any difference. I put it in drive and its at 1000 or 1100. I have changed the mass air flow sensor and relay. I have tried to adjust the idle by the idle screw, but for some reason the throttle thing wont even touch the screw. I try to push it back towards the screw but no nothing. Well let me know what you think or how I should adjust it. Thanks Joey
Old Aug 15, 2001 | 10:59 PM
iroc5speed's Avatar
mine did the same thing, turned out to be a vacuum leak between the carb and the intkae manifold. check for that.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 17, 2001 | 01:36 AM
EO273KiD's Avatar
My 89 w 350 TPI did the same thing for a while...
until I adjusted the timing, adjusted the TPS sensor, cleaned my throttle body, set my fuel pressure and set the idle screw after disconnecting the IAC motor... i got the process from the tech articals..
good luck
Old Aug 17, 2001 | 02:09 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
As previously mentioned, vacuum leak, timing. It'd also do this if you forgot to plug the IAC motor back in. That's kinda a longshot, but easy to check.
91 Z28
Come see The Vicious...
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
