Tech inspection at the drags
Old Aug 16, 2001 | 10:23 AM
z28dan's Avatar
Does anyone know what is involed at tech inspection at the dragsrtip? All they said was that the follow NHRA rules. This is just a test and tune session. Thanks!
1988 L98
Vette Heads/no EGR
SLP Headers/Y-Pipe
ARAP bin
Old Aug 16, 2001 | 10:48 AM
85transamtpi's Avatar
I see you are from chicago so heres the scoop...I went to byron last weekend and didnt even have to open my hood, Be prepared for a FULL inspection if you go to Rt. 66. They will give your car the equilivant of a prostate exam! My advice, go to byron...you'll get more runs and not have to worry about tech, as long as your car is in okay shape.
Old Aug 16, 2001 | 11:07 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All cars that race must be considered safe. The majority of all the street cars are fine but there's little things you may not be aware of that tech may find.
Go the the Calgary Drag Racing Assiciation web page and click on the Tech Inspect button. You can also look at the Secret Street page. That should cover everything you need to know to race at an NHRA track.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 16, 2001 | 11:09 AM
z28dan's Avatar
Not cool! I am running a 66 this weekend! I can't think of what they might check, the car is basiclly stock, The only think is maybe the battery hold down. It's a over sized battery so it doesn't fit the tray. The car is in great shape, I plan checking the luggs and stuff like that. How far is Byron? I live near you, Wheaton.
1988 L98
Vette Heads/no EGR
SLP Headers/Y-Pipe
ARAP bin
Old Aug 16, 2001 | 11:10 AM
ATOMonkey's Avatar
Just make sure the battery is secure, and that your seat belts, steering, and all that good stuff is up to par. You're probably just fine.
Old Aug 16, 2001 | 05:12 PM
irocbsa's Avatar
If you have to, use bungee cords to hold the battery down. That's what I did when I was at a track in Virginia. The guy was pretty strict but it worked.
bsa
Old Aug 16, 2001 | 06:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Bungie cords won't pass at our track but some steel mechanics wire will pass a temporary fix.
If the battery is too big for the tray mack a hold down. A piece of flat bar heavy enough so that it doesn't bent easily (3/16 - 1/4" thick). About 1" wide and long enough to go right across the battery. Drill some holes in it for threaded rod (redi-rod). Bolt the threaded rod to the tray and sucure the battery so that to doesn't move when you grab it and shake it.
Old Aug 16, 2001 | 07:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by Stephen 87 IROC:
</font>
Diddo, here they wont pass either.
A few years back they only wanted the yellow cord "tow rope" now they want steel hold downs.
You will not be able to race unless you get that fixed. A hold down is cheap but if the track jock is in a bad mood a big battery wont fly. Id like to know how a battery will fall out going in a straight line? More likely it will fall out on the way to the track. But like mentioned its a cheap fix just make it look like the battery fits.
SSC
Old Aug 17, 2001 | 10:10 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey, uh, that battery isn't half-in/half-out of the tray indentation, is it? I've heard you can crack the bottom of a battery that way... put a flat plate down across the indentation, then make your hold-down.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Lbibb
May 5, 2016 12:00 AM
jaridjohn
Oct 5, 2015 07:01 AM
bjpotter
Oct 4, 2015 07:48 PM
