Roller rocker and camshaft question
Old May 12, 2005 | 12:25 AM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
I'm looking to order some roller rockers and a zz4 cam. Should I got with 1.6 or 1.52 rockers? Also, to change the cam, cam I just remove the rockers, rods, and intake manifold to change it? Or do the heads need to be completely removed? Is there anything else I should change with the camshaft like bearings or anything else? Motor is a 350 TPI.
Old May 12, 2005 | 12:55 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
To change the cam you'll need to take off the valve covers, intake, pushrods, lifters, drive belt(s), accessories, water pump, balancer, oil pan, timing cover, timing chain, radiator, A/C condensor, and probably a couple of other things I've forgotten.
The block has to be out of the car to change the cam bearings, so as long as they look good you might want to skip that.
Old May 12, 2005 | 04:58 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
ZZ4 cam specs:
Duration @ .050 Lift
Intake 208 .474
Exhaust 221 .510
the ZZ4 is too big for stock heads. You'll need to modify them.
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
