Easy Fuel Filter question
Old May 12, 2005 | 08:09 PM
Stephenlynn98's Avatar
Car: Grey 1988 Camaro
Engine: 2.8 V-6
Transmission: Stock
When changing the fuel filter there are 2 bolts on each side of the filter. I know that you need 2 wrenches for the job. I know that you need to hold on to one of the bolts and twist the other so that the line doesnt twist and end up looking like a twizzler. My question is which bolt do I twist and which do I hold? I dont wanna screw this up! Thanks in advance.
Old May 12, 2005 | 08:16 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
better get line wrenches and maybe a fuel filter wrench. a fuel filter wrench is a 12 point wrench that's thin but has an open end. hold the big one and use a line wrench to loosen the smaller one
Old May 12, 2005 | 09:03 PM
Engine: 2.8 V-6
Transmission: Stock
Thanks for the info. Its appreciated. I am assuming though if I cant get my hands on these wrenches mentioned, the wrenches I already have will suffice correct?
Old May 12, 2005 | 09:06 PM
they'll work if you're careful not to round the corners off. Then you'll be stuck using visegrips. I got a set from sears for like 20 bucks. If it starts to slip off stop
Old May 12, 2005 | 09:07 PM
Engine: 2.8 V-6
Transmission: Stock
Thanks again.
Old May 12, 2005 | 09:33 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
lots of pb blaster if its rusty before you start. I start spraying days before I remove.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
