Cutting weight in car
Old Aug 17, 2001 | 01:18 PM
BJK85Z28's Avatar
From: a tiny cardboard box located at your local garbage dump
What have you guys done to lower the weight of your cars? Anyone remove the back seats? If so, how many pounds did it remove?
Old Aug 17, 2001 | 01:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Search the archive. There are many comments on reducing weight.
First of all you need to know what you want to do with the car. If it's going to stay street legal, there's only so much weight you can remove. If you don't care about appearance or factory safety features then there's a lot of weight you can remove.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 17, 2001 | 02:24 PM
BJK85Z28's Avatar
Thank you. I'll search the archives.
1985 Chevrolet Camaro Z28 Sport Coupe
LG4 305ci
700-R4 auto
Old Aug 17, 2001 | 02:57 PM
ATOMonkey's Avatar
I've done this with every car I own. First thing, I ditch the spare and the jack. Second thing to go is the heat/sound insulation under the carpet along with any undercoating that may be in the interior. Third is all of the undercoating under the car in the wheel wells etc. Emissions equipment along with climate control is the next thing to go. The rear seats only save like 5 lbs, so I generally don't worry about it plus you can still haul your rowdy friends around. Radio speaker delete is good for 10-20 lbs. You can do all of this and still have a car that doesn't look like a racecar. If you want to go all out without buying new parts the seats, carpet, electric deck lid mirror and window motors, interior, and dash have to go. If you still aren't light enough it's time to start spending money. It's pretty straight forward from there.
[This message has been edited by ATOMonkey (edited August 17, 2001).]
Old Aug 17, 2001 | 03:04 PM
camaro6spd's Avatar
you are right to some extent, before you rip out your interior you can do manythings and still look stockish, One switch stuff to Aluminum, like the driveshaft, heads, H2O pump, manifold(if you have a iron one), etc etc. that cuts so much weight. AC weighs alot too so he is right there, and anything you can live without get rid of, I don't reccomend getting rid of you carpet insulation b/c if this a daily driver then you will get ROAD NOISE, I know I and girls don't like that.
Old Aug 17, 2001 | 05:54 PM
ede's Avatar
ede
i went as far as removing the bulbs from my car, plus used a glass hood, removed carpet, seats, heater, spekers, wiper motor, spare, trim panels, turn signal switch, anything and everything went to save weight, all depends on hw radical you want to get.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 17, 2001 | 08:26 PM
camaro6spd's Avatar
ede your car is not street legal, i think this guy whats a street legal one.
Old Aug 17, 2001 | 09:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
That's also why I never mentioned all the stuff I removed from my car to remove weight (and I'm not done). It could never be made street legal again. My goal is to get it down to 2800 pounds with me in it.
Old Aug 17, 2001 | 11:43 PM
BJK85Z28's Avatar
Thanks for the info, guys. Your help is greatly appreciated.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Terrell351
Jun 13, 2021 01:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
