I found an engine
Car: 1987 Camaro Z28
Engine: 305 carb for now
Transmission: 5 speed
I found an engine
actually, I found a car for fairly cheap. My problem is right now I need emissions testing and I have a carb setup on what was efi therefor chances of it passing are not so good. If I get something other than a 305/350 block I can get past emissions as "a hot rod" so I've been looking to get a bigger engine. The one I've found cheapest is from a cadillac it's a 500 would this fit in my Z28? is it the same as a standard swap or would I need different mounts cause its from a '75 caddy. Any recommendations?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You need custom fabbed everything and tons of hammmers, saws, grinders, torchs and hundreds of hours to waste.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need a BOP bellhousing tranny since the Caddy uses the same bolt pattern.
Here's all your Caddy performance parts.
http://www.cad500parts.com/
NinjaNife
Aug 23, 2015 11:49 AM
