Timing Cover Marks on a Early Model/
Old Aug 17, 2001 | 09:39 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Here is my problem: I built a 1974 350 and put it in my 88 camaro that had a stock 305. I used the timing cover from the '74 but I had to use the harmonic balancer from the '88. The problem is that the timing mark on the '88 timing cover is in a different spot then the '74. I can't figure out where exactly my TDC is. Does any one know how many degrees these two marks are apart?
Old Aug 18, 2001 | 02:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Find TDC by looking in the #1 cyl through the spark plug hole, watch for the piston to come to the top, use a dial indicator or get imaginative to figure out when it reached the exact top, & mark either the balancer to match the cover you've got or vice-versa
ICON Motorsports
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
