Vette alum heads... What sparkies to run?
Car: 91 camaro
Engine: 383
I plan to use Delcos, but I noticed that a corvette L98 calls for something like a FR5LS while a camaro L98 gets a CR45TS. Which one should I use with my vette heads? I was planning on using the plugs recommended for the vette. Advice?
91 Z28
Come see The Vicious...
91 Z28
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
My ZZ4 motor came with MR43LTS. I am currently running R44LTS AC Delcos.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There is a different number because Corvette aluminum L98 heads are different than Camaro/Firebird iron L98 heads. If you're using the Corvette heads, use spark plugs recommended for them.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
eightsixseven
Dec 16, 2024 01:50 PM
