leak with new afpr
Old May 15, 2005 | 07:55 PM
88Z's Avatar
88Z
Car: 88 Iroc
leak with new afpr
Just got done installing new fuel rails with afpr on em. As soon as i start cranking my motor, fuel starts spraying out of the fuel pressure test connector. I had no idea what to set the regulator at, so the screw is backed out a bit. Is there any chance that my pressure is set too insanely high? No idea what could be causing this....
Old May 15, 2005 | 08:50 PM
rezinn's Avatar
Fuel is spraying out of the schraeder valve?
Well, first of all crank the screw down until it is getting no resistance. Then stick a fuel pressure tester on and see if you can get a reading to adjust it. Hopefully the valve isn't broken but it sounds like it might be.
Old May 15, 2005 | 09:33 PM
88Z's Avatar
88Z
Car: 88 Iroc
Well I took another look at that little guy.....and the needle in the center was gone. It was completely hollow. Guess i shoulda checked that before i put it on . Swapping on the one from my old fuel rail did the trick.
RS Reaper
Oct 17, 2018 07:52 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
