can a vacuum leak cost me power?
Old May 15, 2005 | 09:20 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
and if so, a lot or a little? my motor is built pretty stout, but it just doesnt seem as fast as it should be. pretty sure i have a vacuum leak, because i have to keep the idle set about 8 or 850 or it will choke and die if i put it lower. any thoughts?
Old May 15, 2005 | 09:23 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
yeah it can be a vacum leak... infact i am sure thats what it is.. when i had my cutless supreme (lowrider) i had to put in park at stops and revs the engine or it will die.. so finnally after 3 days i looked and looked then i found the disconneted hose on the carb that was hissing. then it went away after i pluged it. so look around or better yet listen for a leak.(PRETTY NOTICEBLE).
Hope you Find the problem.
Old May 15, 2005 | 09:25 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
a vac leak will raise your idle. you're on the right track.
Old May 15, 2005 | 09:30 PM
1meanGTA's Avatar
well i knew that, but can it cost my engine not run as strong as it should?
Old May 15, 2005 | 09:35 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
of course. especially on a fuel injected car. your computer will be constantly trying to richen the burn from all of the unmetered air entering. This will reduce throttle response, gas mileage, and acceleration. You're also shortening the life of your spark plugs (to an extent) and catalytic converter, but that's not really a big deal. You're not HURTING much with a vacuum leak, but you're not running at 100% potential. In short answer to your question- yes.
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 21, 2015 05:51 PM
bamaboy0323
Aug 15, 2015 07:20 AM
