basic head porting questions
Old May 16, 2005 | 03:27 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
ok what I'm wondering here is where are the weak spots on head flow?
I know a lot of ppl shave the area near the valve guide to help out with flow and a few other things that I don't remember right now and wondering how just doing a few minor things like this to the head would help out with power?
I'm not interested in making the ports much bigger if anything would like to do it removing the least amount of material possible and instead just remove restrictions or reshape a little. this way I can still keep the low end power.
also on top of just how much of an ipmrovement can be made by reletivly minor head work what impact would just a basic head job do for gas mileage?
Old May 16, 2005 | 03:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Have you checked out the Standard Abrasives Do-it-yourself Porting Guidelines?
Most of the gains appear to come from cleaning out the bowl under the valves, where the factory machining operation stops and leaves a ridge in the casting; and the "short side radius", the transition from the port to the valve on the "inside" of the turn.
Next is valve shrouding - depending upon the size of valves & chamber you have, may or may not be an issue.
Smoothing out/reducing the guide seems to be of benefit as well.
Old May 16, 2005 | 06:02 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
how would this minor reshaping affect gas mileage?
I'm interested in getting a little more pep without losing gas mileage and if anything would like to improve it
Old May 16, 2005 | 06:46 PM
Vader's Avatar
With which head castings will you be working?
Old May 16, 2005 | 11:46 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
first car kinda depends
a friend and I are going junkyard shopping tomorrow to see if we might be able to pick up a decent set of heads for a fairly mild carbed 350. mostly stock other then what we think is upgraded cam and edlebrock carb
the other car that we might try this on is the ol' cvcc honda head
and if all works out might have another car to try it on as well while doing a mild buildup of a poncho 428
the 428 is on hold for the time being though the main motors are the 350 which the heads I can get the casting number tomorrow if you want but that can change when we go junkyard shopping if we can find another good set of heads. any recomendations? and the cvcc honda head
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
