help please help need answers fast help
Old Aug 19, 2001 | 08:34 PM
CamaroRS1990Guy's Avatar
Car: 1990 Camaro RS
Engine: 305 soon to be 383
hey i just got through testing my Diagnostic Connector and it came up with code 23 for the fuel injection model and it says it is in the Manifold Air Temperature Sensor it says Poor electrical connection, open or short circuit; defective MAT(Manifold Air Tempature sensor)sensor; defective ECM .....>>>>>> what should i do
Old Aug 19, 2001 | 09:56 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Well I don't know how to test the MAT but here's a way to test your ECM.....with the car running take the computer down from under the dash and free it from the plastic bracket. Try to flex the ECM lightly and tap it with the palm of your hand. If the car stalls or starts running rough then your ECM is more than likely toast.....just don't use too much force when you're doing this test!
Riccioli Performance Motorworks
--RPM Racing--
Getting there.....383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now let's pray it runs when it's all back together!!!!
Old Aug 19, 2001 | 10:30 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
<font face="Verdana, Arial" size="2">Originally posted by Paul Riccioli Jr:
</font>
Ahhh, the ever famous GM "tap test".
I have done this one and it does work if performed with a gentle touch.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
InfernalVortex
Apr 20, 2021 11:31 AM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
