Might have to put my baby to sleep?
Old Aug 19, 2001 | 12:52 PM
slowmaro92305's Avatar
hey, i got a question. i have a 92 rs with a 305 tbi. last night i noticed this ugly sound. its like a rattling or kinda like a tapping sound coming from the engine. it gets louder when i accelerate and lower when i deaccelerate. is this a blown piston or what else could it be? if it is the piston...would it be cheaper to fix it or replace the engine? please respond quickly. thanks in advance.
Old Aug 19, 2001 | 01:23 PM
zerogauge's Avatar
header came loose and made same sound...as exhaust seeped out around the gasket.
hard to tell unless you start digging into it. loose rocker arm maybe? valve lash
could be lots of things
Old Aug 19, 2001 | 02:44 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Could be a ton of things, like loose rocker arm, bent pushrod, spun bearing, or it may not even be in the engine, like loose torque converter bolts (assuming you have an auto tranny).
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 19, 2001 | 05:50 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Does it make the knock when the car is idling? If it doesn't then it could be(and I know this will sound strange)low octane gas. Are you using reg., mid., or high octane. Now if it does it while the car is idling then you could have a lot of different problems. Just a thought.
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Aug 19, 2001 | 07:00 PM
yea it does it when idling. it just gets worse and worse when u accelerate. i wanted to put a zz4 in but guess this kinda changes things cuz i dont have the money for it yet. anyone know of any cheap performance engines?
Old Aug 20, 2001 | 06:46 AM
87tpi420's Avatar
cheap and performance should never go in the same sentence . dont go the "cheap way" you are much better off to save money and do it once and do it right......TRUST ME!!
as everyone else said,could be many things from the noise,could be a few minor things, or you could need a new engine, but let us know when you find out. good luck!!
http://people.ne.mediaone.net/gdm
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
Old Aug 20, 2001 | 09:16 AM
El Guapo's Avatar
this is off the wall, but have you checked your oil? It could be valve tap caused by low oil.
Clayton
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
