intake q's
Old Aug 20, 2001 | 11:59 AM
AlexJH's Avatar
Engine: 5.7L V8
intake q's
I blew a head gasket a while back, and I'm starting to put things together... the machine shop put my intake into the parts washer, but now I can hear water or something sloshing around inside it. Should I be worried?
I had left most of the parts attached to the intake, including the brass coloured thing on the top. I'm not sure what it's called, it has an electrical connector and a vacuum line I think.
Old Aug 20, 2001 | 12:33 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
They probably didn't hot tank it if there was any brass left on the intake, so maybe they just stuck it in a solvent bath. Could be your EGR valve? I dunno, but I'd mix up some soap and hot water and clean it up, then rinse out with a hose. Blow with compressed air, or let it dry in the sun...don't think I'd want to install it with something in there, whether it be liquid or solid, until I knew it was all out.
Old Aug 20, 2001 | 01:55 PM
AlexJH's Avatar
Engine: 5.7L V8
That's right... it was just a solvent bath I guess.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
