383 single plane cam suggestions
Old May 18, 2005 | 11:23 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I am building my new 383 now and I am in need of camshaft suggestions. I am using a Professional products "Hurricane" single plane intake manifold that I am converting over to fuel injection for the 383. I still have my Trick Flow Kenny Dutteweiler 64cc ported heads and a CR around 10.7-11.0. Hooker Long Tube Headers and the 25 lb hr injectors. The engine will be a 75% driving and 25% racing. Yes, I burn my own '730 chips. I have an LT4 hot cam from the last project I will throw in to start it with. But what cam should I go with? Is there a different approach to selecting a cam for a single plane than EFI?
Old May 19, 2005 | 09:42 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Anyone?
Old May 20, 2005 | 06:45 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I would suggest a Comp XE HR 230/236 112 lsa installed at 109 degs. You will get a good midrange and top end power with this cam while still having the ability to maintain decent idle vacuum.
www.geocities.com/dzperf
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
LT1Formula
Aug 20, 2015 09:36 PM
sreZ28
Aug 14, 2015 07:48 PM
Jake_92RS
Aug 11, 2015 10:39 AM
