Throttle problems
Old May 19, 2005 | 01:24 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 3.73
Throttle problems
I got the car running and it idles on it's own (although just a tad rougher than it was before hand), but when I give it throttle, the car bogs down and almost dies, but goes back to idling just fine when the blades aren't open. Any ideas? Thanks.
Old May 19, 2005 | 05:48 PM
sellmanb's Avatar
Car: '86 Berlinetta
what's fuel pressure?
what's base timing at?
did you double check for vacuum leaks?
what happened to the car before?
what parts did you replace/touch?
Old May 20, 2005 | 12:44 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
I don't have a timing to tell my base timing, and I don't have a FP gauge. I checked and I have no vacuum leaks. I swapped out my stock TPI for the Stealth Ram. It now doesn't bog down when I give it gas, but it won't rev any higher than 3k rpm. Would too much advance in timing cause that?
Old May 20, 2005 | 11:37 PM
sellmanb's Avatar
Car: '86 Berlinetta
I'd guess it would be more related to fuel pressure.
You arent trying to do this on the stock chip are you?
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Sep 4, 2015 07:57 AM
perZ
Aug 15, 2015 01:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
