wont start!!! cranks but no fuel
Old May 19, 2005 | 09:48 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
Alright whats wrong? My car wont start it cranks. but no fuel is being delievered. my fuel pump isnt coming on. No ses light. I have vats disabled through the ecm. Im thinkin its the control module under the distributer? or what else could this be? i have a 89 camaro rs
Old May 19, 2005 | 10:00 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Could also be VATS if your car has it.
Old May 19, 2005 | 10:02 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Re: wont start!!! cranks but no fuel
There is a cam and oil pump shaft under there, no control module's at all.
About the fuel, do you have a fuel pressure gauge? What is the resting pressure and what is the starting pressure?
Old May 20, 2005 | 12:09 AM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
PhLaXuS I already stated that i had the vats disabled via a custom chip.
HalfInchWrench if my fuel pump isnt kicking on how would seeing the fuel pressure have anything to do with it. Also i mistated that part of my question. I ment under the distrubetr cap theres a electronic spark module. Could that be the cause? Again thanks for the help both you guys for the quick replies
Old May 20, 2005 | 12:38 AM
Engine: SBC, LS-x
[BHalfInchWrench if my fuel pump isnt kicking on how would seeing the fuel pressure have anything to do with it. Also i mistated that part of my question. I ment under the distrubetr cap theres a electronic spark module. Could that be the cause? Again thanks for the help both you guys for the quick replies [/B]
Back to basics. Need fuel and spark.
It could be. What makes you think it is the ignition module?
Old May 20, 2005 | 12:49 AM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
well i really dont know what it is actually. I know im not getting any fuel dont know bout spark but the car is cranking. when i turn it to the on posistion it does have the ses light on like it shoud though making me think its got somthing to do with the computer too. Could the electronic spark control being bad make this happen?
Old May 20, 2005 | 01:17 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You mention the FP isn't coming on...check the relay...check the wiring, get a Chiltons and a meter and get busy
Old May 20, 2005 | 01:19 AM
Engine: SBC, LS-x
Yes it could. I've seen folks say they work or the don't. Seen myself that they can work one minute and not the next. Kinda like a woman. I have spare parts to swap on so it doesn't matter much for me. Always nice to have in a process of elimination.
Old May 20, 2005 | 01:24 AM
Engine: SBC, LS-x
Ground terminal F on the ALDL connector under the dash. Does that work?
Old May 20, 2005 | 07:59 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
tried grounding the f terminal. dont think that worked. Still not getting the ses light. replaced the ectronic spark control module. I know im getting spark since i was electricuted lol. But if my ecu was bad i wouldnt turn on the fuel pump right?
Old May 20, 2005 | 09:20 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
'G' terminal, not 'F' and you don't ground it, you apply power to it
Apply 12V to the 'G' terminal to bypass everything and test the pump!
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
For future reference...
Old May 21, 2005 | 01:48 AM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
thanx red devil. But is there any reason why my ses light isnt coming on when i turn i the ignition to the on posistion?
Old May 21, 2005 | 09:39 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Check the ECM fuse by the battery.
Old May 21, 2005 | 04:42 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Doesn't terminal D flash all the dash lights on when grounded...or is it just the SES light. Could even be a burnt bulb, but based upon other things not working, maybe not.
Old May 21, 2005 | 04:46 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
checked the fuse it was broken. drove it around all night then started it again today and it just died down the road on me. again fuse broken. what could be the cause of this
Old May 21, 2005 | 09:11 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
well its the fuse for the ecm. The thing keeps blowing after awhile! Also my cars fan is kicking on for no reason and going back off and im shooting water out of my tail pipes on start up. my ecm is giving me no codes. what could it be?
Old May 21, 2005 | 09:25 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Well...unless someone has had this type of thing before and knew what caused it, you may have to probe the wires on the ECM for shorts.
http://www.diy-efi.org/gmecm/ecm_info/1228746/
Intermittent stuff sucks. A few months back, my power trunk kept popping fuses -- turned out my cig lighter in the dash was shorting out when I placed the heating element in. I don't smoke...I just didn't like a big hole in the dash.
Old May 22, 2005 | 07:42 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Could a bad battery be causing it?
Old May 23, 2005 | 07:46 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Not very likely. The ECM fuse is popping because the ECM (or soemthing attached to it) is drawing too much current. Maybe if the alternator is overcharging the battery...but probably not. As long as the battery is ~12.5V with the car off & ~14.4V with it on, the charging circuits look good. It's probably either a dead solenoid (a dead short could draw too much current) or one of your +5V reference lines (such as for TPS) that 's grounding out to the chassis somewhere. Honestly, as long as you understand electricity even a little, probably the easiest way to find a short is to pull the ECM from the car and measure directly across the ECM harness pins to see what's gone wrong. There are other ways of testing, but this way is pretty easy because evrything you need to test is right in front of you.
Old May 24, 2005 | 08:29 AM
Hrock's Avatar
Seen this happen before. PHLAX is Right. Your ECM can not handle a resistance of less then 10 ohms. Also check that your ECM has a Well Inserted Prom..
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
