Torque specs on knock sensors
Old Aug 21, 2001 | 12:58 PM
chiefz28's Avatar
Anyone know the torque specs on a knock sensor for a 91 Z28.I looked through my Haynes Manual but no luck.Thanks in advance
1991 1LE Z28 355cu 5SPD (ORIGINALLY 305 BEST E.T. 14.186@99.86mph)NO PASSES ON 355 YET.MINI RAM INTAKE,AFR 190 HEADS,10.23:1cr 24# SVO INJECTORS,BBK 52mmTB,AFPR
FULL ROLLER MOTOR,1.6 rockers MSD 6AL
AUTOMETER A/F GAGUE MARCH PULLEYS,HEDDMEN HEADERS 3IN EXH NO CATS FLOWMASTER,POWER TRAX NO-SLIP LOCKER,3:42 GEARS,LAKEWOOD LOWER CONTROL ARMS HOTCHIKS STRUTTOWER BRACE,COMPETTION ENG.SUBFRAME CONNECTORS
MALLORY TACH W/SHIFT LITE
BLACK, TINTED WINDOWS, TAIL LIGHT COVERS BIG BLOCK COWL INDUCTION HOOD,SHAVED DOOR HANDLES
67RS 327cu 92K ORIG MILES.NEWER GM HEADS HEADERS,650 HOLLEY CARB,CAM, 350 TURBO TRANS W/SHIFT KIT&COOLER 12 BOLT POSI 3.73'S MUTLILEAF SPRINGS
NEW VINYLROOF&CARPET, COWL HOOD,HIDE AWAY HEAD LITES,
Old Aug 21, 2001 | 01:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a pipe plug... is usually use about 4 wraps of Teflon tape so that it goes in easy, and about 20 ft-lbs. Don't over-torque it, that ruins it by making it too sensitive.
ICON Motorsports
Old Aug 22, 2001 | 12:54 AM
nFORM91's Avatar
Hey guys,
This may pertain to this subject. Ok, I'm getting occasional knock retard on my '91 Formula (305 TPI with only 36,800 original miles).
The car runs fine and strong for a 305, I might go a week or two just fine. Then out of nowhere, retarded timing and SES. I don't hear any knock and if I shut the motor off - wait a few minutes then start it again, it may come back in 5 min, or go a week with no problem! Is my knock sensor torqued too tight? (causing over-sensitivity?) Please help!
p.s. I did do a diag with a GM tech and he said to replace the knock sensor. If I could wrap a few layers of teflon tape on it would that actually de-sensitize the damn thing? Thanks
[This message has been edited by nFORM91 (edited August 21, 2001).]
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
willyjoejr
Sep 3, 2015 09:26 AM
masonta
Sep 1, 2015 06:40 PM
