1.6 Roller Rockers - Wat should I get?
Old Aug 22, 2001 | 05:35 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
Thinking about installing some 1.6 roller rockers on my '89 IROC, what brand/type should I get - And is there anything else I need to replace when installing them?
Will they fit under the stock valvecovers?
Anyone who has done this, some advice/hints would be nice!
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Old Aug 22, 2001 | 06:48 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Compcams Pro magnums are the best for a street car. They are made of steel rather than aluminum. Ive never used 1.6 ratio rockers before so I cant comment on them.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited August 22, 2001).]
Old Aug 22, 2001 | 09:22 AM
ATOMonkey's Avatar
The only advice that I can give that I'd never thought of until I was building a 383 with my brother is spring bing height. You can only mash those little suckers so far and then you start breaking stuff. With 1.5 rockers and .505 lift cam we were coming real close to bind with stock height aftermarket springs. If you measure everything and leave yourself a minimum of .030-.040 clearance, you should be fine.
Steel is definately the best choice for the street, because Aluminum no matter how thick has a compression/tension cycle limit. Steel has no limit if the stresses are low enough. Also the full roller rockers are the best, but if you can't afford that go with roller tips, because they reduce friction and help out a lot on valve geometry.
As far as brands I haven't had any experience with this, but go with a big name for best customer support and reliability.
Old Aug 22, 2001 | 12:55 PM
92fire-audio's Avatar
I was wondering about these too, whats involved in the installation? I thought it would just be like: take off valve covers, unbolt stock rockers, place new rockers on, torque them down, put valve covers back on, do an oil change...
What else is there to it? I didn't know you had to measure spring hieght or anything but I'm fairly new to working on valvetrains so I'm probly wrong..
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
