Berlinetta column into 84 Trans Am
Old Aug 22, 2001 | 08:32 AM
TransAm383's Avatar
Okay I can get a pretty good deal on a steering column from an 84 Berlinetta for my 84 TA. The berlinetta has push button lighting, so it doesn't have the turn signal mast on the column. How hard would it be to adapt a turn signal mast to this column? Or should I just wait for a column with everything I need already on it? Thanks.
Old Aug 22, 2001 | 01:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The thing to do would be to check out the plugs where it hooks up to the rest of the car's wiring. I would suspect that either they're the same, or that you need some of the donor car's wiring, in which case it's not worth the trouble. It should be obvious just looking at the connectors.
ICON Motorsports
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
Pemberton76
Aug 15, 2015 07:15 PM
