Dimmer Switch Adjustment???????
Old Aug 22, 2001 | 06:54 PM
rscamaro91's Avatar
Does anyone know how to adjust the dimmer switch on a camaro, I can only brighten and dim my lights if the steering wheel is all the way up or down. Thanks in Advance..
Old Aug 22, 2001 | 08:39 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Umm, IIRC all that the dimmer switches are, are potentiometers. No adjustment needed.
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Aug 22, 2001 | 08:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The dimmer switch is mounted on top of the steering column, down near the firewall. It's held on IIRC with 2 ¼" screws. You just loosen them and slide it up or down until it correctly meets the rod that the lever goes to.
ICON Motorsports
Old Aug 22, 2001 | 08:46 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
OK, let me get back to this, re-reading your post, do you mean that your high-beams only come on when your steering wheel is all the way up or down? Does your steering wheel have alot of up and down play?
Old Aug 22, 2001 | 08:49 PM
rscamaro91's Avatar
I meant that i can only brighten and dim them with the whee all the way up or down, and no where in between......
Old Aug 22, 2001 | 08:50 PM
rscamaro91's Avatar
oh, and what is IIRC
Old Aug 22, 2001 | 08:57 PM
irocbsa's Avatar
IIRC, is If I Recall Correctly, IIRC.
My damn dimmer switch has broken off its mount. Gotta pull the gauge cluster to fix it too. GRRRRRRRRRR. Ah well.
bsa
Old Aug 22, 2001 | 09:01 PM
rscamaro91's Avatar
so this switch is all the way at the bottom of the steering column, what does it look like??
Old Aug 22, 2001 | 09:21 PM
Vader's Avatar
RS,
It looks just like item #66, and is (appropriately enough) "actuated" by item #69...
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
Old Aug 22, 2001 | 09:35 PM
rscamaro91's Avatar
thanks alot for ur help, i will see tomorrow if i can locate it.....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
