hei
Old Aug 22, 2001 | 09:48 AM
jd's Avatar
jd
hei
I just wanted to verify an article that I read somewhere, can,t remember where. It said if your engine will crank but you have no fire to the plugs, then put a testlight on the tach terminal at the cap. Ground one end of the testlight and touch the other end to the tach terminal, and have a helper crank the engine. If the light flashes on and off, it means the pick-up coil and ignition module are ok. Is that correct? thanks
Old Aug 23, 2001 | 08:08 AM
jd's Avatar
jd
<font face="Verdana, Arial" size="2">Originally posted by jd:
I just wanted to verify an article that I read somewhere, can,t remember where. It said if your engine will crank but you have no fire to the plugs, then put a testlight on the tach terminal at the cap. Ground one end of the testlight and touch the other end to the tach terminal, and have a helper crank the engine. If the light flashes on and off, it means the pick-up coil and ignition module are ok. Is that correct? thanks</font>
Hey guys, thanks anyway, I found the article, I was looking for.
sreZ28
Oct 22, 2015 08:21 AM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
