valve keepers
Old May 22, 2005 | 05:29 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
valve keepers
I'm loosing my freakin mind on these valve keepers. I got the first head done not too much of a problem but on the second head EVERY valve keeper is seized to the valve stem. I sprayed them down with cleaner and I gently tap on the spring compressor with a rubber mallet. If I tap too hard the compressor comes flying off. I'm about to take my sawzall to these sons of b*****s
Old May 22, 2005 | 05:50 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I had the exact same thing happen. I hit the valves lightly with a hammer before I compressed the springs, plugged the oil holes in the head, and then put a magnet on top, compressed the springs, and eventually they came off. Try twisting, too.
So far replacing my seals has been the biggest PITA on my car..
Old May 22, 2005 | 06:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Beat the retainers a few times with a rubber mallet before you put the valve spring compressor on. After you've done it a few times, you'll recognize the sound when the retainer comes free, especially if you're using an air holder.
Old May 22, 2005 | 06:54 PM
I already had the heads off the car. A guy from the other board told me and I did the rest of the cylinder head in the time that it took me to do one valve on the other head. The idea came from
Techinspector1 at
www.clubhotrod.com
Take two pieces of wood to lift them off the work surface and take a socket (i used 21 mm) put the open end over the keepers and I used my 5 lb hammer and stike the socket it'll compress the spring and shoot the keepers out into the socket. Wonderful idea that saved a ton of time and cut the profanity by 2/3's.
Old May 22, 2005 | 07:01 PM
305q_ta86's Avatar
Transmission: 5 spd
Wow, yeah, good idea. Next time I have to do that with the heads off...
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
