V-belt to Serp
Old May 23, 2005 | 09:55 AM
ponykiller1992's Avatar
Car: 89 formula 350
Transmission: Stock 700r4
V-belt to Serp
I want to convert my 87 TPI to a serp belt set-up. I was just gonna buy the stuff off of someone. Is there a certain year or something I should be looking for, or will any year serp setup work?
Old May 25, 2005 | 12:04 AM
CAH383's Avatar
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
The 3rd gen F-body serp setup is the same from 88-92. Very easy to do. You will also need a serp crank pulley and a new water pump as the serpentine pump spin's counterclockwise.
Old May 25, 2005 | 01:02 AM
rezinn's Avatar
There's some place in florida that used to sell conversion kits. I paid around $150 for it a four or five years ago. It just includes all of the accessories and the brackets, pulleys. I don't know if it's still in business because I can't find the website, but maybe you can. AFAIK any year should work, even some different car models would work.
Old May 25, 2005 | 01:07 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Available over the counter at your friendly neighborhood GM parts counter.
GM P/N 12497697 w/o A/C
GM P/N 12497698 w/ A/C
Complete kits, including the belt, brackets pulleys, tensioners, idlers, water pump, alternator, P/S pump, A/C compressor and mounting hardware.
2012sergen11
Oct 13, 2015 07:38 PM
MantyZ28
23
Sep 29, 2015 11:33 AM
evilstuie
Sep 24, 2015 02:31 AM
MrDano
Nov 22, 2000 09:49 AM
MrDano
Nov 20, 2000 09:19 PM
