ac condenser
Old May 23, 2005 | 11:24 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
ac condenser
Sorry to bother you guys again, since im doing a rebuild on my engine and I didnt even have an ac pump I figured to just delete the darn thing.
I can remove the condensor and not worry about it right? I'm worried that too much air will just flow around my radiator rather than through it.
Also, I guted the box thats on the passenger side firewall, is that safe to just leave gutted? Or do I have to plug that big hole.
Old May 23, 2005 | 11:37 PM
ManoftheHour's Avatar
as far as i know the air will flow throught the radiator just rhe same if not better.
as for the box for the heater, you need to plug it up. I used duct tape for the longest time. Because exhaust into the cabin is bad. And i have periodic collector leaks.
But now the duct tape seams to have melted away from the heat of the headers.....
MTH
Bubbajones_ya
Jul 6, 2024 08:32 PM
b4ccamaro
Jun 5, 2016 01:48 PM
my86bird
Oct 23, 2015 12:20 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
