will this cam work with my heads?
Old May 24, 2005 | 03:41 PM
rsn932's Avatar
what cam to work with my heads?
14094093 casting number heads
i had a comp cams cam with .464/.464 lift in the 350, but that cam is worn out. i liked how it worked, but summit doesnt have it anymore. whats a cam that is very similar to this that will work with stock heads and the same springs that the old cam used. advertised duration was 268/276, 114 LSA
thanks
edit: this is a hydraulic flat tappet cam, not a hydraulic roller, so i need a flat tappet since i cant afford the retrofit roller setup
Old May 24, 2005 | 04:01 PM
rsn932's Avatar
would the CS XE268H-10 work, or is that too big?
Old May 24, 2005 | 05:15 PM
91Z28-350's Avatar
No clue on your heads, but if your heads are anything like the 081/083 heads, then .480" lift is pushing it (near the limit) for the pull-out studs and the valve guide boss clearance. Did you ever check the lift clearance when you did your old cam or valve springs?
I don't know if you would need to go with the "computer controlled" version though. 12-268-4 (XE268H-14). The 110 LSA may cause issues with your computer.
Your old cam was probably 12-404-4 (268AH-14).
Maybe give Comp Cams a call and see if they have any info on your heads?
Old May 25, 2005 | 08:32 AM
rsn932's Avatar
sorry typo the heads are the 083. i bought it as a crate motor, it already had screw in studs. i don't know about the valve guide boss clearance
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
anesthes
Aug 8, 2015 09:37 PM
