412 Build Started Tonight..And Yesterday Night
Old May 25, 2005 | 02:03 AM
JesasaurusRex's Avatar
So guys got all my stuff back from the machine shop, had them tank it,bore/hone it .030, align bore and drill outside bolts for my splayed main caps, sqaure deck it, and balance my rotating assembly.
Excited as i was i pretty much jumped right to it (when i had time ofcourse). Now the only problem is i got #1 in turned her over a few times no problemo. Dropped #6 in, turn her over 1ce no problem, turned her over again and CLUNK!!!! damn rod is hitting the cam so im guessing im going to have to grind it down (actualy rod itself). Anybody have any suggestions?
Oh and specs are as follows
412ci's (.030 over and 3.8" stroke) 4 Bolt Splayed Caps w/ ARP Main Studs
Eagle 4340 3.8" stroke Crank w/ 400 mains
Scat 4340 6" H Beam Rods with ARP 8740 Cap Screws
SRP Forged 4cc Domed Pistons
Super Victor Intake
AFR 220 Heads 76cc Chambers
Solid Roller Cam
264/272 @ .050
.649/.649 Lift
107 LSA
850CFM Might Demon Carb
If im missin somethin you want to know about go ahead and ask and ill let you know.
Here are the pics
Old May 25, 2005 | 12:01 PM
AllGoNoShow's Avatar
Looks awesome! that thing is going to haul.
Did you put cam lube on the cam bearing? In my directions I was told only to put oil on the cam bearings but many solid rollers are different.
Old May 25, 2005 | 01:43 PM
If you mean many solid rollers are different as in some dont need to have lube inbetween them and the bearings your wrong. But yes i did put lube on the cam bearings.
Old May 25, 2005 | 02:10 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I know on most 383's you have to run a small base circle cam. I dont know about the 412's. Just something to think about.
If you grind on the rods, then you will have to get everything rebalanced.
Old May 25, 2005 | 03:27 PM
I know im thinkin about it
How will a small base circle cam help tho i mean i realize the base of the cam lobe is smaller but its not hitting the base of the cam....
Old May 25, 2005 | 06:54 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Not only is the base smaller the lobe is smaller by the same amount. The lobe still has the same lift and everything, its just that the lobe starting point is closer to the centerline of the cam.
Old May 25, 2005 | 07:53 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Three thing that you need.
1. Water
2. Soap
3. A collection of scrub brushes
Clean out that lifter valley. That's filthy. You do know all the gunk will be mixed in with the oil, don't you?
Old May 25, 2005 | 08:39 PM
Got cha, guess thats what imma have to do then damn...more money
Old May 25, 2005 | 08:40 PM
1. Water
2. Soap
I know i know
Old May 25, 2005 | 08:46 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
when i put solid roller in my 406 i needed a small base circle as well...and the purpose soild roller lifters too
Old May 25, 2005 | 09:43 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
When I built my 406 I used capscrew rods and there were a couple spots that still needed grinding. They guys that balance assemblies for my machinist did the clearancing, I guess from experience they know where their supposed to remove the metal. Sounds like you'll have a strong combo.
Don't forget to paint the block.
Old May 25, 2005 | 10:12 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
1. Water
2. Soap
4. resize those monsterous pics
Old May 25, 2005 | 10:18 PM
Lets say i get a smaller circle base cam with the 4/7 swap? That add or subtract any clearance? Im sure i could figure it out but im too lazy to try n do it in my head
Old May 26, 2005 | 08:10 PM
Well i just ordered a small circle base cam, 300+ bux
Anyways so this cams for sale if anybodys interested
https://www.thirdgen.org/techbb2/sho...hreadid=300379
Old May 28, 2005 | 02:40 AM
Some more progress for those that are interested
I cant find one of my head stud nuts :cry
Old May 28, 2005 | 12:13 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
wow that one side looks real good
when you install head studs, are you supposed to strectch them as you would with arp rod bolts?
also what is the advantage to head studs?
Old May 30, 2005 | 12:43 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
in a couple of those pics it looks like a quick change timing cover in the background........... I ran one on mine and it leaked like a sive and I had to reseal it twice with a ton of gm's special sealant before it would quit. It was the one thing I did wrong in my last buildup was put on of those on.
Everything else looks sweet man!
Old May 31, 2005 | 08:29 PM
Donno if you are supposed to stretch them like you would bolts but i did just incase
Well i donno what the real advantage of them are but i know some of those bolts were a BITCH to get to on those AFR heads, i had to grind down the sockets so skinny that i broke 2 of em.
Old May 31, 2005 | 08:31 PM
Donno what pic you saw it in but ya i got a cloyes 2 piece cover, i had a mr gasket one before and just like yourself it leaked like hell. Hopefully this one is better, now im just having issues with my gear drive fitting underneath it fixed it to where it fits under but now i gotta get the clearance right inbetween the idler gear and the block...
Couple More
Old Jun 2, 2005 | 04:35 PM
And some more, just threw the intake on for ****s n giggles didnt seal it up yet since i still gotta put my lifters/cam in.
and the long tubes
Old Jun 2, 2005 | 11:23 PM
daverr's Avatar
looks very good.im in the process of building a 426 sbc myself .what compression is your motor?? are u going to dyno it???
Old Jun 3, 2005 | 01:14 AM
11.25 - 11.5:1 static
9.44 - 9.65 dynamic
ill get it dynoed when its in the camaro not just the motor tho
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
TheExaminer
Aug 26, 2015 04:59 PM
92camaroJoe
Aug 13, 2015 06:07 AM
