Someone has to be able to answer this.....
Old Aug 24, 2001 | 05:02 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Can I run a combination cooler in a car with air conditioning?? If anyone is, what brand are you running?
Riccioli Performance Motorworks
--RPM Racing--
Getting there.....383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now let's pray it runs when it's all back together!!!!
Old Aug 24, 2001 | 06:53 PM
Guest
Guest
Posts: n/a
Sure, why not?
Old Aug 24, 2001 | 08:39 PM
Biochem's Avatar
Car: 2002 SOM z28
If you mean by "combination cooler" a tranny cooler or oil cooler or coolant cooler or some sort of radiator-like cooler in front... then the answer is "yes". Pick your brand.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Aug 25, 2001 | 07:33 AM
Car: 89 IROC-Z
Engine: 383
I know that theoretically there is no reason why I can't, but what I want to know is where the hell to mount it. And it's a oil/tranny fluid cooler that I'm talking about. I was thinking of putting it infront of the condenser, but then the radiator will get less air I think.
--RPM Racing--
Old Aug 25, 2001 | 07:51 AM
Biochem's Avatar
Car: 2002 SOM z28
I would suggest you use some sort of 1/2"=1" spacers to keep it a bit aways from the condenser and you'll be golden. The main thing you need to watch out for is those little cross bars... If you yank the AC, you'll have plenty of space
Old Aug 25, 2001 | 07:53 AM
ede's Avatar
ede
buy the combo cooler with a pusher type fan on it. i've never really tried or looked but i ithnk you could mount it behind the fan, between the fan and ater pump, you'd just have to make the mounting hardwear solid so it didn't get chewed up on anything.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
grngryoutmyway
Oct 18, 2016 05:48 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
