No oil going to the heads.... please help
Old Aug 25, 2001 | 08:58 AM
FasNuf91's Avatar
i just fired off my new motor last nite... 350, MiniRam, AFR 195's.... anyways while i was breaking it in, I noticed the oil pressure was at 35 pounds when i was holding it a 2500rpms.... at an idle the guage reads 10 pounds.... i pulled the valve cover off and noticed that the rocker arms are completly dry... what could possibly be the promlem... i know that the bottom end is getting oil because i pulled the plug that sits behind the intake and oil shoots out of there.... any help will be appreciated thanks..
Old Aug 25, 2001 | 10:12 AM
Vader's Avatar
FN91,
Do yourself a big favor and DON'T run the engine any more! You'll need to verify that the rear cam bearing was installed correctly and is providing oil to the lifter oil galleries (and thus push rods and rockers). Also make sure the gallery plugs are sealed in the ends of the lifter galleries. Front plugs missing or leaking won't leak externally and may not be obvious.
It will be far safer to remove the distributor and use an oil pump priming shaft in a large electric drill (or hand crank) to test the lubrication system. Eventually, at least one of the push rods should start getting oil flow if the assembly is correct.
You should also check the filter to make sure it isn't plugged from debris and assembly lube.
This might help, too:
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
[This message has been edited by Vader (edited August 25, 2001).]
Old Aug 25, 2001 | 10:19 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yep...What Vader said.....
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
