Shift Points
Old May 26, 2005 | 02:22 PM
91Z-TheReaper's Avatar
Car: 88 IROC
Engine: 350 L98
Transmission: T5 - 5 Speed
Shift Points
Why has my in-dash shift light started going mental?
Some days it doesn't tell me to shift, some days it tells me to shift at say a grand when I'm doing 30 in 4th...
All of a sudden. This is new.
Another example, I can bottom out 4th at about 900 rpm (Not that I should be, just as an example), and yet it is telling me to shift...
So what controls that light? What are/should the stock settings be on it?
I realize that you can run a grand or so above the recomended numbers, I'm just curious what my car is trying to tell me.
I'm running a '90 Vette L98 w/ WCT5
Old May 29, 2005 | 10:26 AM
Vader's Avatar
The shift light doesn't really operate at any definete points of data, but rather as a result of calculated data. Throttle position, vehicle speed, engine RPM, coolant and intake air temperatures, measured intake vacuum, calculated engien load, and the status of options (like A/C) will affect the operation points of the shift lamp.
Your example seems like a problem, however. Has anything been changed recently, like rear gears, a MAP sensor, etc?
Old May 29, 2005 | 12:36 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Since you have changed quite a bit of stuff it may affect how the light works, but who needs a shift light anyway, I can tell when to shift WAY better than that stupid light, if I watch mine and try to use it during normal driving it doesn't come on untill I'm way past the rpm that the car needs to shift at.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Out-Cast
Sep 11, 2015 08:03 AM
