anyone that has an autometer air/fuel ratio gauge....
Old Aug 27, 2001 | 09:02 AM
CamaroZ_85's Avatar
I just put mine in the other day cause i wanted to do some lazy mans carb tuning. anyway the thing acts weird as hell. if i'm just cruising down the street, it usually doesnt read anything unless i punch the gas, in fact it usually only gives a sensible reading when i'm on it. at idle, i have my carb nearly as rich as it can go and this gauge reads anywhere from no reading to very lean to just about right. i'm just wondering if i have some sort of problem here (no vacuum leaks, i checked) or this thing just acts funky....thanks
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
[This message has been edited by CamaroZ_85 (edited August 27, 2001).]
Old Aug 27, 2001 | 12:00 PM
turtle's Avatar
from what i have read on this board the O2 sensor in these cars are less then perfect. basicly they either read rich or lean and thats about it. i have an autometer a/f from my old car that i havent installed yet just because of that reason.
now i am new to the camaro world, chevy's to for that matter, so do a search and see what it comes up with. my thoughts on the problem are that if the stock O2 wont read much beyond lean/rich a wide band O2 is the only cure.
Old Aug 27, 2001 | 03:12 PM
CamaroZ_85's Avatar
i actually spent the money for the autometer heated O2 sensor that you're supposed to use...
Old Aug 27, 2001 | 03:36 PM
Jester's Avatar
A stock style O2 (even a heated one) is sufficient, but it does have limitations the further you get from 14.7:1.
if you are rich past 12:1 or so it won't read right at all....usualy showing off the charts lean. Lean your carb out a bit...see if you can get the readings to make more sense.
Also use plug reading to suppliment the gauge. If the gauge reads lean, but the plugs are black..it's a good clue you're rich off the charts.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
InfernalVortex
Apr 20, 2021 11:31 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
