Is 350 direct replacement for 305
Car: Dirt Street Stock oval track 2bbl
Engine: 350 w/dart iron heads and 383 w/world products sportsman II heads
Transmission: saginaw
I've got a worn out 305 in a car and a rebuilt 350 in the garage. What needs done to swap engines?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Yes. However to take full advantage of it you would benefit by upgrading your exhaust system, induction system, etc. But like said above just search, this ones been covered probably thousands of times here.
Search and search somemore a ton of info on this subject.
