Mileage Question?
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Mileage Question?
Hey Dudes on my car, evertime I get gas the car takes about 13 gallons. I don't run it totally dry. It has a 15.5 gallon tank. If I am figuring things correctly about my mileage, I go about 180 miles (Between gas fill ups) This comes out to about almost 14 miles per gallon around town. I have a 5.7 TPI, with no major mods, just exhaust,(No Cat) and rapid fire plugs. The car has 100,000 miles on it. I drive her pretty fast sometimes, but for the most part baby her. Before my tune up, I was getting around 11 miles per gallon around town. Does 14 MPG seem to be ok for around town driving for my vehicle? I have never been able to figure out highway mileage yet.
Thanks in advance for the info!
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
You explained my gas situation perfectly. Everytime I get gas, I fill it up and get about 12.5 gallons into a 15.5 gallon tank. AndI get about 190 MAYBE 200 miles to a tank when I drive around town mostly. I don't have any major internal engine mods either. I'm getting an MSD 6A... hopefully that will help it out a little. I'll let you know how that works out.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, throttle body coolant bypass, Spohn SFC's on order, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
2.8 MPFI, no mods
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
I usually get anywhere between 250 and 270 driving around town and if I'm on the highway I can get anywhere between 290 to 320 depending on how hard I am on the gas and or how much passing and what not. I usually dump about 13 to 14 gallons in the tank on most all fill ups.
FYI
j.wolfe
_ ____ _
91 GTA L98
Best time: 14.389@95.49 (VMP)
"...Deception..." Brandon Sloan * ...wounds heal and chics dig scars...
FYI
j.wolfe
_ ____ _
91 GTA L98
Engine: ZZ4 - 350
Well if you are geting that good of mileage poor boy, I better check some things out on my car. Because I thought 14mpg was not to bad, but you are doing great. I can never break 200 miles per tank around town. You are getting about the same mileage that I was getting with my 89' 3.8 liter V-6 Delta 88. How the heck you are getting that kind of mileage out of a 5.7 I do not know. What gears do you have??
Thanks guys. Anyone else have any comments?
Later
Mike
Later
Mike
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
I get just about the same mileage as poorbooy. It's 88' IROC-Z 5.7 TPI, 700-R4, And 2.77 Gears. I have gotten that mileage since I performed A FULL tuneup.
Car: 1989 IROC-Z
Dam.... how do u do so well???
I have brand new AC Delco plugs, maybe I should get a new coil and cap and rotor while I'm at it.
I know it doesn't really apply, but in my carbed LG4 305 I get about 20mpg in town and about 25-27 mpg highway. Despite the extra 45 cubes, I'd think you should be doing at least as well as I am, especially with fuel injection.
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I have an 86 IROC with a 305 TPI, 700r4 and 3.42 pos. I get between 20 and 21 mpg around town. I've only been on one trip (500 plus miles with the back loaded with gear) and between the interstate (70 to 80 mph and running around home (no gear and doing the speed limit - mostly) I got 23 mpg on each of 3 fill ups. There is only one way to calculate mpg. 1. fill the tank up each time (keep putting gas in even after the pump kicks off - you'll know when it's full), 2. write down your mileage off the odometer, 3. when you get gas, do #1 again, then #2 again, 4. subtract the first mileage number from the second mileage number, then divide the miles travelled by the gallons of gas you put in it. I always hear people say, "I drive back and forth to work 6 or 7 days on a tank of gas, it's about 30 miles round trip and I put 10 gallons of gas in it so that's about 20 mpg, right?" Wrong. By the way. I'm tickled to death with the IROC's mpg. The 81Z (350/4spd) gets 13 to 14 mpg around town and 17 on the highway. The 83Z (305 HO and 700r4) gets 11 mpg in town with no trips to figure highway mpg. Have a nice day.
Z's r Best
Z's r Best
13.5 MPG last time i filled up, chevron gas doesn't seem to give me as good milage. most i ever have gotten was 16 MPG city, with about 21 MPG freeway. no a\c easy driving
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
My '88 GTA, 5.7, has seen over 30 mpg several times on hilly-curvey country roads.
Most of the time I average 26-28 mpg.
Even on tanks where I have several track runs, I still get at least 18 mpg.
My car has headers, cat-back (no cat), Wells MAF, ram air/cold air and several other mods, and has seen 14.06 at 99.5 at the track. All for fuel mileage, of course---wink-wink.
Most TPI cars were factory rated at mid to high teens in city driving and mid-twenties for highway driving.
If your car isn't getting that kind of mileage, there probably is something wrong. Ever check tire pressures or front-end alignment?
Perhaps a lighter right shoe is in order! lol
jms
jms
Engine: ZZ4 - 350
Hey Breathment & L98IROC89, it looks like we all get about the same mileage. Everyone else seems to be getting alot better than us. I don't know what else to check on my car. It runs perfect. When I tuned it up, the old plugs were just perfect in color (Light Brown) so I am not running rich. The car Idles perfect. around 600 RPM's. My timing is right. I don't think it is my heavy foot, but I will really see this time since I have been the easiest on the car with this tank full of gas so far. I do use the air alot, that might have something to do with it also. I thought 14 mpg wasn't that bad, but I really don't know what else to do. My older 1989 Delta 88 with a 3.8 V-6 got worse mileage than some of these guys are getting with there V-8's! I was getting about 17 mpg's with that car around city with the air on all the time, and about 21-23 on the highway. And that car was a elderly owned beauty before I got it. Maybe my Maybe our TCC lockup isn't working. How do I know if this is working right?
later Dudes
Mike
later Dudes
Mike
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by West Coast GTA Man:
Maybe my TCC lockup isn't working. How do I know if this is working right?
</font>
</font>
I get about 19-20 mpg commuting, about 24-25 all highway, and my TCC does not lock up. Carbs CAN get decent mileage...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Oh, if you want to know the real capacity of your gas tank, put about 1/2 gallon in a can in the trunk, and run the tank completely dry. Put in the gas from the can, drive immediately to the nearest gas station, and see how much it holds.
Engine: ZZ4 - 350
Hey man, if I find that my TCC isn't working properly, how do I fix it? Also my gearing in the rear is 3.27's. This could be part of the reason that my mileage isn't as good as some of the other guys in here. I am going to check my TCC for sure though.
Later
Mike
Later
Mike
Car: 91 Z/28 convertible
my 92 (L03) gets an average of 300 miles on a tank of gas and i run the air conditioning wide open at all times my 89 with no air gets areound 200-220 mpg
92 25th annv. camaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
spoiler
92 stock rims
92 ground effects
later Dudes
Mike
</font>
later Dudes
Mike
</font>
Engine: ZZ4 - 350
Well I have 3.27 gears also Breathment, and this has to be some of the prob. But I just tested my car today on the way home from work, and my TCC is not working properly, so I know this is part of my mileage prob. I am going to post a question about this.
Later dude
Mike
Later dude
Mike
<font face="Verdana, Arial" size="2">Originally posted by L98IROCZ89:
I have brand new AC Delco plugs, maybe I should get a new coil and cap and rotor while I'm at it.</font>
Engine: ZZ4 - 350
Maybe I will have to try some MSD ignition parts, it certainly won't hurt any, and maybe I will even get a little more power.
C-ya
Mike
C-ya
Mike
Car: 1991 Trans Am
Transmission: 4L60
I get over 200 miles on a tank in town and I run my AC in 100*+ weather. If I don't run my AC, it's around 240.
91 TA 5.7 TPI Automatic.
w/WS6 and 3.23 rear.
K&N Air Filter,Hypertech Coil,Moroso Blue Max Wires, Bosch Platinum plugs gapped at .050,
JET fan switch,JET air foil,Dual cats with Flowmaster 3" exhaust (Headers coming soon),
Complete PST components on front suspension, Spohn LCAs/Panhard bar.
It's not much, but it's a start and I have a Summit catalog! :-)
Engine: ZZ4 - 350
I am doing 14 mpg around town, and have to check more into my TCC. I think that is the only thing that is causing my mileage to be a little worse than it should. It could also be that I put a 170 thermostat in, and a cooler fan switch, so the motor might be burning a little more gas until it warms up. Also, some of you in here say "driving around town" I know that "around town is a little different for all of us. Where some people live it is more highway type town driving, but where I am at it (near Tampa) it is bumper to bumper-stop go, lights every friggin mile, 95 degree weather etc. OHH alright, I will just try to stop making excuses for my poor mileage!
Take care guys
Mike
Take care guys
Mike
Careful about the MSD, i got one and noticed all of no difference in my car. I think for those of you who it makes a big improvement for, it may be a sign that something else in your ign. system is below par.
83 Z28--not a pretty site, sold thank goodness
74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
Last time I checked my mileage I got 17mpg. I have gotten as good as 25mpg on the highway. This is with my LB9 with 700r4 and 3.27 gears. Then again I have gotten as bad as 11mpg when im on it.
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
Gas mileage is a funny thing. I have two cars, a 92 3.1 mfi firebird and an 87 ws6 Trans am with 305 tpi and 3.27 gears. Both of my cars are automatics and I was getting about 22-24 in my v6, around 20 in town. I'm getting about 18 in town with my v8 and around 23-25 on the highway. Ofcoarse, I'm not an easy driver, I used to run the hell out of that v6. I don't run the 8 as hard, but I don't have to.
Engine: ZZ4 - 350
Well I am almost there. I am in the ball park here. But I want better.
C-ya
Mike
C-ya
Mike
