a/c support bracket needed?
Old May 29, 2005 | 11:59 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
I'm swapping out my 305 for a new ZZ4, I've also installed an a/c delete pulley.
Do I need to re-install the a/c support bracket that runs to the exhaust manifold?
Is this to help support the weight of the a/c unit or to reduce vibration?
Thanks if you can help.
Old May 30, 2005 | 11:21 AM
Vader's Avatar
If you are asking about the diagonal brace between the exhaust manifold stud and the compressor upper mount, it is intended solely to reduce vibration of the compressor during operation.
Attached Thumbnails a/c support bracket needed?-compressorbrace.jpg
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
