which marks when checking Ignition Timming. HELP
Old Aug 27, 2001 | 08:21 PM
breathment's Avatar
ok, im trying to check my ignition timming, but i don't understand where its supposed to be. i see the mark on the crank pully, but i don't know where to lign it up with... heres a picture (kinda)
is there supposed to be #'s on there or something, im clueless here.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT
Old Aug 27, 2001 | 08:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
One of them is 0°, I think it's the 2nd one up from the bottom... look at the tab closely, it's on there... they are 4° each notch, so from bottom to top they're 4° retarded, then 0, then 4 adv, then 8 adv, etc.
ICON Motorsports
Old Aug 27, 2001 | 10:46 PM
GTA88's Avatar
You might have to wipe off some grime to see the numbers. I don't remember exactly where the numbers are, but they are near the spikes, of course. I could only see a couple of them and had to figure out what the other notches represented.
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Aug 27, 2001 | 10:55 PM
rezinn's Avatar
Im pretty sure one of those grooves is larger than the others, that should be zero.
BRoss99
Aug 10, 2025 05:08 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
