WOW put a new Fuel Pressure reg in and Now Code 44 Running Lean
Old May 30, 2005 | 02:32 PM
IonNight's Avatar
Car: 1986 Iroc Z
Engine: Truck 305 /Bored .30 Flat Pistons/ Crane Cam
Transmission: Corvette 700R4
I am very confused ..... At first my camaro was running rich at 7000 HC's on emmissions. I replaced the Fuel Pressure Reg
and now its reading Lean... code 44 wow
Car seems to lack power and my gas/oil gauge are still bouncing up and down slightly ever so often...
Any help would be awsome
Old May 30, 2005 | 04:14 PM
IonNight's Avatar
Car: 1986 Iroc Z
Im so confused now
Old May 30, 2005 | 07:16 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Whats the fuel pressure now?
Old May 30, 2005 | 10:47 PM
formula2fast's Avatar
Car: 87 Pontiac Firebird Formula
Engine: 355 SBC-Thats all I can say or they will break my legs.
Transmission: 5 Speed
I think you are misunderstanding your emissions readings. Your Hydrocarbons (HC) is an indicator of a misfire (engine not running properly or not having complete combustion), not whether you are running rich or lean. Carbon Monoxide (CO) is your indicator of rich and lean. When you have excessive HC but your CO is low, you have a lean misfire. I bet that is what you are seeing. I would be curious to see the rest of your reading are. You can pretty much diagnose anything by reading emissions readings. Hope that sends you in the right direction.
Old May 31, 2005 | 04:11 PM
IonNight's Avatar
Car: 1986 Iroc Z
This is what the Emission showed with the results.
co% 3.95 with the limit of 1.10
HC% 7375 w/ the limit of 275
No % 340 w/ the limit of 3600
RPM= 1452
Dilution 11.5%
air inj sys=pass
egr system = pass
pcv system = pass
fuel inlet restrictor= pass
cat conv= pass
evap ctrl sys= pass
gas cap= pass
Old Jun 5, 2005 | 01:05 AM
IonNight's Avatar
Car: 1986 Iroc Z
could the timing be off now??
Old Jun 5, 2005 | 09:52 PM
IonNight's Avatar
Car: 1986 Iroc Z
put fuel pressure tester and ran car... steady at 40
shut car off and it slowly dropped to 20 withing 30 seconds or so then slowly dropped to zero..
I checked the fuel injectors and there not leaking... im still confused
I thought the pressure was supposed to hold steady and not drop more than 1 psi an hour... what is causing it to run lean and the pressure to drop when i shut the car off...
I turn the key but I do not start the car. The pressure shoots up to 40 sits there for a bit n then drops slowly and then slower till finally no pressure is left...
Its running lean and it doesnt make any sense to me... bad check valve in fuel pump??
The car was perfect... it only sat for 7 years.....
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
86IROC112
Aug 17, 2015 02:00 PM
Kaweh
Aug 9, 2015 02:54 PM
