vent control vacuum tank
Old Jun 5, 2005 | 10:35 AM
ctw41's Avatar
Car: 92 Z-28
Transmission: automatic
I have no vacuum for my controls so I went looking for the the vacuum tank that is supposed to be a ball shaped object on the left fender under the hood on my 92 Z. Can't find anything except the charcol cannister.
Any place else it might be?
Old Jun 5, 2005 | 08:48 PM
Vader's Avatar
Ahh, the elusive "Sphere of Nothingness", a.k.a. "Pooterball", "Dilithium Chamber", "WTF Izzit Ball", or the more mundane, factory term, "Vacuum Reservoir". It should actually be on the outside of the inner fender, well hidden above the wheel well and partially visible through the openings stamped through the inner fender at the LF corner. It is forward and outboard of the washer fluid container.
Old Jun 5, 2005 | 09:30 PM
ctw41's Avatar
Car: 92 Z-28
That's a heck of a place to stash it. It must be forward of the horns. I found a small hose coming out of there and it runs back towards the master cylinder and it's plugged with a screw. That may be my vacuum source and why my controls are stuck in defrost. Looks like I have to take the wheel off to get to it
Old Jun 5, 2005 | 10:44 PM
Vader's Avatar
I('m not sure if this will work on a Chevy, but on my Poncho, I can remove the fasteners from the lower filler panel for the ground effects and air dams, and flex the filler panel away enough to get good access to the area in question. Look at it from the underside to see if it's a viable option on your's.
chazman
Aug 28, 2018 03:25 PM
theshackle
Mar 5, 2017 06:37 PM
Todd84Z
Sep 4, 2015 08:02 AM
chazman
Aug 22, 2015 02:01 PM
mustangman65_79
Aug 11, 2015 03:17 PM
