Gas in Oil
Old Jun 5, 2005 | 09:31 PM
Huffs_91_RS's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 342 Posi
Gas in Oil
I recently built my engine. Went from 305 to 350 and TBI to Carb. Well it spun the #'s 3 and 5 ROD Bearings and screwed the crank up . The engine had no oil press. and when I got the oil drained it was like water, but smelled like gas bad. What would cause that? Had a manuel pump pullin through the elec. The elec pump was unhooked. Any replys would be great.
Old Jun 5, 2005 | 09:39 PM
katman's Avatar
Car: 91 Z28
Engine: 468 ci
Transmission: thm 350
Floats stuck and flooded?
Old Jun 5, 2005 | 09:43 PM
Car: 84 Z28
Engine: 383
Thought that too. Checked that and it wasnt that. Thanks!!
Old Jun 5, 2005 | 09:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did you use a mechanical pump? I've had instances when the diaphram ruptured and gas spurted into the crankcase.
Old Jun 5, 2005 | 09:52 PM
Car: 84 Z28
Engine: 383
Yeah I had a mechanicle pump pullin the gas through the elec pump. The elec pump was unhooked. Tore the engine down today, I didnt notice anything like u just said while I was taken the fuel pump off.
Old Jun 5, 2005 | 09:54 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You'd have to take the pump apart to know...but it's the only other way for fuel to get inside the carnkscase, othet than the carb.
Old Jun 5, 2005 | 10:00 PM
Car: 84 Z28
Engine: 383
I get what ur sayn on the fuel pump. I really dont think that is what it is. I checked the carb and then my dad took a look at it. Floats where fine and so was the needle.
Old Jun 5, 2005 | 10:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
ONly other thing that you can't see is maybe the fuel pump you used is a higher pressure rating than the carb can take? In that case the [pump can push the fuel through, and over come the needle seat in the carb.
My last guesss
Old Jun 5, 2005 | 10:17 PM
Car: 84 Z28
Engine: 383
Thanks man. Im going to get the fuel pump and see if I can find out what type of fuel press it is suppost to create. The carb is a Holley 600. It possible is the carb. Ill make double sure before I put it back together. Hotrodn isnt cheap and I dont have a fat wallet.
Old Jun 5, 2005 | 11:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
A Holley shoud be good to 6-8PSI, I know I ran an E-Brock and was told that it would only hold the float seat to 5-7PSI...can't verify for a fact because I ran what I was told, but just food for thought if you're running a high performance pump.
Good luck, there aren't that many holes for the fuel to flow through
1992 Trans Am
May 10, 2023 07:19 PM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
