How fast can rod knock occur?
Old Aug 28, 2001 | 07:26 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I was doing a few hard runs to test a new PROM. Afterthat I drove the car a half mile normally. It drove fine. Stopped it. Restarted it a minute later and pretty much let it idle about 20 ft, at which point it started knocking
This was pretty much an instantaneous thing and I wasn't even giving it gas. I'm really hoping it is some other part of my valve train. But in reality I know its not!
Old Aug 28, 2001 | 07:46 PM
FlashGTA
Guest
Posts: n/a
So your question is what?
Old Aug 28, 2001 | 09:13 PM
Guest
Guest
Posts: n/a
It can happen in a small enough amount of time you cant measure it.
It *may* be a lifter. Try to find out if the noise is from the bottom end or top end. Bad exhaust gaskets make a tapping noise, dont know how bad the noise is on your car.
Old Aug 28, 2001 | 10:14 PM
87tpi420's Avatar
how do you know its not? is it distinct? knocking can be many things. why would go get rod knock because you stopped and restarted it? i am lost on that one. knocking can sometimes be cracked/broken flex plate. timing chain?
hope its not your rods/crank
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Aug 28, 2001 | 10:39 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I had a rod knock go from very queit, barely audible, to 3 spun bearings and 6 broken piston skirts in about 3 hours (long story). It souned like......It was indescribable. If you think you have a rod knock, have it checked. An experienced mechanic can tell the difference MOST OF THE TIME.
92Z28
89GTA
Old Aug 28, 2001 | 10:55 PM
Aaron91RS's Avatar
Car: RS
See thats why I am holding out there is a slim chance it's something else. It didn't slowy increase. It came on loud enough to hear in the car immediatly.
I pulled the valve covers and didn't see a mis-aligned rocker. But I am so depressed I haven't looked at it again and don't want to. My car has been constant problems for too long.
In fact I was on my way to get the slipping tranny rebuilt when this happened.
grngryoutmyway
Oct 18, 2016 05:48 PM
Nervous2
Oct 8, 2015 10:53 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
