plug the crankcase vent filter hole?
Old Jun 1, 2005 | 01:27 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
real quick question, i think its pretty simple i just dont know for sure.
ive got a pcv valve on one valve cover and a crank vent filter on the other. i went to a open element, and didnt want that ugly filter tube there and i had a plug that fit in the filter hole perfectly. it should be okay plugged since i have a pcv, correct? thanks.
-daniel
Old Jun 1, 2005 | 01:44 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Nope, it won't. For the PCV to be able to draw (vacuum) out the vapors, there has to be someplace to draw from, a source of fresh air.
Think of sucking on a straw. If you put your finger over the other end, it doesn't draw much does it? That's what your plug will do. Now put the breather filter back in that hole and you're getting clean filtered air thru that straw.
Make sense now?
Old Jun 1, 2005 | 02:31 PM
Car: 89 camaro rs
Engine: 305 tbi
thanks vern. so theres an in and an out, but being plugged makes for just an out. okay i got it. now i gotta get a grommet cuz it broke on removal.
were can i get one of those pop in filters locally. the kind that jegs and summit sell. because i need one by tomorrow lol.
Old Jun 1, 2005 | 02:34 PM
vernw's Avatar
I've seen breathers at O'Reilly's and Autozone, so I imagine your local parts chain would have them as well.
Old Jun 1, 2005 | 02:37 PM
Car: 89 camaro rs
Engine: 305 tbi
ok thanks. are you talking about OE breathers or the little canister shaped ones, be cause i didnt see any the kind im thinking of at autozone yesterday.
Old Jun 1, 2005 | 02:40 PM
vernw's Avatar
The little (2" diameter) round ones made by Mr. Gasket, etc., would work fine.
Old Jun 1, 2005 | 02:42 PM
Car: 89 camaro rs
Engine: 305 tbi
ok.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
BurlyChev
Aug 22, 2015 01:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
