AFPR setting for my motor
Old Jun 1, 2005 | 10:20 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
Well I finally got the TPI running right again and I now need some opinions on where the fuel pressure should be set...... For carbed apps on my motor (GM 350 HO Crate), the pressure is recommended at 8 psi if I remember correctly. Now I have the Vortec intake TPI unit sitting on there right now with the AFPR dialed in at 44 PSI. Does that equate to the carb setting??? I also noticed that the preferred timing set up is 10*. I have mine set at about 7* (any higher and I ping).
Gimme your suggestions...I would love to get this thing running to full potential.
Later
Old Jun 1, 2005 | 11:07 PM
rokn91rs's Avatar
well if u have the pressure set at 44 thats a good start but, if u want to find out were your car runs the best you need to take it to the track and adjust it there see what pressure gives u the best results.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mhatfield 14
Oct 24, 2015 07:48 AM
TheExaminer
Aug 26, 2015 04:59 PM
