Having trouble finding right VSS for T5 swap
Old Aug 29, 2001 | 03:49 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Ok, i'm putting a T5 from an 85 bird into my 90 RS. The 85 bird used a cable speedo. My RS uses an electronic speedo.
I tried to order an electronic VSS for a 90 RS and the sensor they gave me way too big. It had like a 2" diameter. The cable speed sensor is only 1" in diameter.
My question...did GM change the tailshaft and sensor housing when they changed to the electronic speedo's????????? Or should the 2 be interchangeable???
(sorry for posting in 2 forums)
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old Aug 29, 2001 | 03:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No they should be the same diameter. Tailshaft et al. is all the same between electronic & cable. For example, right now I have a 91 T-5 (came to me with VSS still installed) in my 83 Z28 with a cable.
Sounds like somebody gave you the VSS for an auto trans.
You can get one out of a trans at the boneyard; AFAIK the sensor is the same regardless of gear or engine or any of that.
ICON Motorsports
Old Aug 29, 2001 | 07:34 PM
Engine: LH0 3.1L
Thanks dood,
The first thing i said when i saw the part was "this looks like a VSS for an automatic". The guy at work special ordered a different one, so i'll see it tomorrow.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
$750 L98
Feb 1, 2025 02:25 PM
thunder57
Nov 7, 2015 02:28 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
Lmancha96
Sep 25, 2015 08:11 PM
