Engine codes
Old Jun 3, 2005 | 10:43 AM
gthmcty1's Avatar
Car: 89 Formula
Engine: 5.7 TPI
Code 32? Changed but still pops up! HELP
Guys I have just acquired a new project 89 Pontiac Formula 5.7 TPI!! And I have been trying to return the car back to normal operating condition. The previous owner tried to "experiment" with the car but nothing I can't address, anyways here is my issue:
Code 32 flashes (EGR) and I replaced the EGR and I drove it around all day yesterday and it run "okay". This morning I get in and crank the car and the SES light illuminates, I check the code and it flashes 32 AGAIN!! Keep in mind I disconnected the battery while I was RR the EGR and for good measure I waited an additional 20 minutes (XBOX Halo2 ) so I know the code had been erased previously from the initial EGR code. But now it has illuminated with the same code and I replaced said defective part!! Any suggestions as to what it may be??? It is driving me crazy!!
Old Jun 3, 2005 | 11:56 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
quick thought. did you check out the connector and wires that the sensor plugs up to ? frayed or broken wires or corroded pins ?
Old Jun 3, 2005 | 12:02 PM
gthmcty1's Avatar
Car: 89 Formula
Engine: 5.7 TPI
I did and the wires were a little "worn" so I reapaire as best I could.
Old Jun 5, 2005 | 07:46 PM
kirk158's Avatar
Car: 89 RS
Engine: 2.8
check them dang vaccum lines had some myself that I thought were good till I pulled them and the under sides were not
Old Jun 5, 2005 | 07:49 PM
kirk158's Avatar
Car: 89 RS
Engine: 2.8
Oh yea did you check the passage ways and make sure you did not have any build up
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
