Caprice 350 Engine (New)????
Old Aug 28, 2001 | 09:11 PM
CloudIROCZ28's Avatar
This Engine complete is $1487 I'm wondering if This would be a good replacement for my IROC-Z and will my TPI bolt up to it????? and what else would I have to do to make it work??? my original engine is a 305 LB9 TPI
1987 IROC-Z
G92, LB9 305 TPI, 3.23, Bright Red with Carmine Interior, Pioneer DEHP47DH CD deck.2 JBL DS645 4*6 (F).. 2 JBL DS965 6*9 (S).. Soon to get new 305 TPI
Old Aug 28, 2001 | 09:38 PM
Hey guys????
1987 IROC-Z
Old Aug 28, 2001 | 09:47 PM
james_fearn's Avatar
It's better than the $1200 engine. I used that caprice engine as the basis for my engine. I sold the heads to my friend and replaced them with edelbrock heads. I replaced the weak camshaft w/ a zz4. That engine is a pretty good choice but I would at the very least repalce the camshaft.
You will have to use your existing dampner or buy a new one because the timing marks are at the 12:00 position instead of the 2:00 that is needed for the TPI engines in order to see the timing marks.
I used this engine to replace my LB9 as well. Everything but the dampner should work w/ out any problems since you have an 87 LB9 w/ the 1-piece RMS and theverticle center manifold holes.
The stock compression is good and it is better than a pepboys rebuild.
James
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC/LCA/PR, GW "wonderbar"
[This message has been edited by james_fearn (edited August 28, 2001).]
Old Aug 28, 2001 | 10:31 PM
humm cool I might buy the new Damper but I have a question should anything be done with the computer because of the TPI???....It sux cause there's no core charge... hummm
1987 IROC-Z
Old Aug 29, 2001 | 08:03 PM
I would suggest a new PROM because you are going from a 305 to a 350 but some people have just left it alone. I would at least get a memcal for a 350 TPI, there are several options for that. That will set you back around $45~60 depending on the dealer.
James
Old Aug 30, 2001 | 05:24 AM
transam350's Avatar
I just put that same engine in my gta over christmas all i did was change the damper and put my TPI down on top of it. It runs great it ran a 15.2 with out even changing anything other than the damper. That was completly stock.
89 T/A GTA 350 TPI free mods and all stock
15.21 @ 89.7
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
