Please help
Old Aug 30, 2001 | 01:28 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Please help
I need to replace my oil dipstick tube, i have a new one, my oil filter is damaged and is leaking oil bad, im going to get a new one now but i have no way of measuring how much oil i need, there are no nuts and it wont pull out, i cant even really see where it is attached i am going by feel, the old tube is too far damaged to be bent back or to get the dipstick in it.
1 5/8 Hooker Competetion Headers, custom y-pipe,no cat, modified Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Old Aug 30, 2001 | 01:47 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
The oil dipstick is held on by one bolt. When you do remove the old dipstick, make sure the old O-ring on the dipstick and not on the block. Make sure you use a new O-ring when putting in a new dipstick. May I ask as to how you put a hole on your oil filter?
Old Aug 30, 2001 | 02:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you can't change the dipstick tube (which can be a real hassle because of where and how it presses into the block), just put 5 quarts of oil in the motor. You won't be very far wrong.
Putting the new tube in isn't too bad; you can just put a 5/16" bolt in the top end of it and whap it in with a BFH. Getting the old one out is the challenge.
ICON Motorsports
