backfiring and popping upon deceleration
Old Aug 29, 2001 | 12:50 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
Ive noticed a great deal of popping and sometimes even backfiring coming out of my exhaust these last few weeks. at first i thought it was totally normal, but its been getting annoying. i heard that my exhaust donuts could be bad, i took my car to midas and they couldnt find anything, what do i do now? are there any exhaust valves that need to be replaced? any ideas? thanks-
1987 LG4 Camaro z28
Performance
KN airfilter, flowmaster 80 series and catco high flow cat, 180* thermostat
System
Panasonic CQ-DF200U deck, fosgate speakers (hpc1369, frc2246)
Old Aug 29, 2001 | 01:30 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Most likely there is an exhaust leak somewhere.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4 vette servo and .500 boost valve
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3" Hooker Aero Chamber
Old Aug 29, 2001 | 10:13 PM
Engine: LB9
Axle/Gears: 3:43
i had them check for an exhaust leak and they couldnt find a thing, they said everything was fine, is there anything else to check?
Old Aug 29, 2001 | 10:20 PM
leirch's Avatar
checked the timing lately? compression check?
is your cat gutted?
Old Aug 30, 2001 | 10:19 AM
Engine: LB9
Axle/Gears: 3:43
im going to check my timing this afternoon but its set at 0*. I just had a new high flow cat installed in june. and no i havent done a compression check, i guess i need to do that one of these days. but other than the smoke the car runs great, and is a beast out of the box.
Old Aug 30, 2001 | 07:48 PM
RS91's Avatar
I had this similar problem. I replaced A.I.R valve. Solved that problem....
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
Lmancha96
Sep 25, 2015 08:11 PM
