car won't start,dash lights/hazard blink
Old Jun 5, 2005 | 01:18 PM
ron83TA's Avatar
Car: trans-am 1983
Engine: LG4
Transmission: TH-200
I made a search but i found nothing that could help me.
My friend has a 1986 trans-am whit carb.We when out for a ride and the car was fine.Now the car won't start.The dash light and hazard light just blink and the little bell is ringing.The fan goes on so it seem like their is some switch or someting that stop the car from working.
He had is car for 2 years and this is the first time it does that.I never seen that on a carb car.It look like an anti-thief device or something.
Any help would be great cause im confused tkx
Old Jun 5, 2005 | 01:52 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
Does the car turn over? If it does not I would check your battery connections, they could be loose or corroded. This would allow the lights to come on, but not have enough to turn the car over.
Old Jun 5, 2005 | 01:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like one of the 2 fusible links has popped. There are usually about 2, sometimes 3; the feeds to various parts of the car are hooked up through different ones. There are 2 halves of the ignition switch, and each half is fed by one.
The one that feeds the half of the ign switch that has the Start terminal in it, is the one that's bad.
Disconnect the pos batt cable from the batt; then disconnect it at the starter; then look carefully at the 2 small wires that share the big post on the starter with the batt cable. You'll find that one of them is burnt in half.
Old Jun 5, 2005 | 06:04 PM
ron83TA's Avatar
Car: trans-am 1983
Engine: LG4
Thank for the imput.My budy is coming down tonite,will check the wire and connection at the battery and starter.For now,all i can do is wait.The car is locked
I'll post later on
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
