Steering column?
Steering column?
Does anyone have detailed or not so detailed instructions on how to remove the column from the car. I figure it would be easier to have some direction than just "digging in". Thank you
87 Black on Black T/A
T-Tops Digital dash
5.0 TPI S/R Torquer 305 heads Summit TPI cam
204/214 @.050 .420/.442
SLP headers and catback
A4 with 3.42 gears
Fully loaded and everything usually works.
T-Tops Digital dash
A4 with 3.42 gears
Car: 4
Engine: 6
Transmission: 5
It's really alot easier than it looks...
One bolt (15mm IIRC) under the hood where the column attached to the intermediate steering shaft; 3 screws (either 10mm or 13mm, I forget) that hold the column's "baseplate" to the firewall; 4 nuts under the dash (15mm), to get to them you'll have to take off the hush panel (4 screws and a nut) and the little panel under the column (4 screws); 1 plug to the turn signals, 2 plugs to the ignition switch, one plug to the dimmer switch, one plug to the cruise control. Installation is the reverse of removal.
ICON Motorsports
ICON Motorsports
thanks looks like I will be doing it this weekend. The column in my car has ALOT of play up and down. I tore it apart tightened everything and used locktite and now a few months later it's loose again. I figure I will just swap a good one from my parts car onto mine instead of tearing it apart again.
T-Tops Digital dash
A4 with 3.42 gears
T-Tops Digital dash
A4 with 3.42 gears
sjorgens
Oct 1, 2015 07:54 PM
