To Jackstand, Or Not To Jackstand?
Old Sep 1, 2001 | 03:40 PM
MartyMcFly's Avatar
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
If I store my car all winter, would it be better to put it up on jackstands, or to park it on some junk tires? Supposedly, the jackstands will bend the frame. So I figured I'd use some junk tires because I know they'll just get flat spotted from sitting for so long. But then I heard that this could flat spot a bearing. What do I do?
88 miles an hour? But Doc, the speedometer stops at 85!!!
Come to the Vicksburg Old Car Show (in Michigan) next year, and hold it up for all the Thirdgen owners out there.
e-mail for directions, dates, etc.
[This message has been edited by MartyMcFly (edited September 01, 2001).]
Old Sep 1, 2001 | 05:51 PM
Vader's Avatar
McFly,
Since I store several cars in winter, I'll share with you my methods.
There is an article on long term storage on the 3rd° site for storage for more than a year. Since you're apparently just wintering your car in the garage like I do every year, here's what I've done:
* Fully charge the battery. There's no reason to remove it if you're only storing for several months, and you'll need it to start the vehicle periodically (more later). As long as it's fully charged, it shouldn't freeze.
* DO NOT wash the car right before you put the ziploc on it. The latent moisture will have fun with your car while you're away.
* If you have a fixed antenna, spin it off and put it in the cargo well.
* Drain and change the engine and transmission fluids just before storage. Normal acid formation in oils will also wreak havoc in an idle assembly. Make sure all other fluid levels are at their safe maximum.
* The consensus of those on the board is to fill the fuel tank. For long-term storage, I would recommend draining the tank to about 1/8th full, but for seasonal storage it isn't a factor as long as you use a fuel stabilizer like Sta-Bil or a similar product at your last fillup.
* Replace the coolant or enhance the heck out of it with corrosion inhibitors.
* Seal all the air intakes and vents you can find. Plastic and duct tape body vents, cowl vents, exhaust pipes, throttle body, etc. The duct tape is a *****' to get off, but it's a lot easier than mouse dung.
* Suspend the vehicle on jack stands from the box channels on the rear body and at the front cross member near lower swingarm mounts instead of letting it rest on the suspension and tires.
* Put a 9x11 cake pan on the front passenger floor to catch the coolant drips from the heater core if it rots through.
* Put fly paper or insect traps on some flat interior surfaces.
* Close the windows and doors tight. Keep the car out of light as much as possible. If you decide to cover it, make sure the first layer is a lightweight breathable material. If you want to keep the paint as clean as possible, lay out some cotton bath towels over the flat surfaces of the hood and roof (over the lightweight cover), then cover it with a plastic tarp.
It would be best if you could get back to it at least once a month or enlist a helper to run it to full operating temperature, operate all the accessories, move the steering and brakes, then store it again. There is usually at least one decent day every month during the winter weekends to enable you to do this. If you don't have that opportunity, you may have some work to do when you do pull it out of storage.
Starting periodically has several benefits. The oils get warmed enough to keep water from condensing in the sumps. The entire engine gets a heat/cool cycle to dry out and distribute oil everywhere. The transmission can be shifted through the ranges to allow fluid flow through most of the valve body and cause movement of parts that might otherwise stick. All the 'O' rings and seals get warmed and wet with oil. The battery gets a load and then fully charged to exercise it. The exhaust system gets purged of moisture. The cooling system gets full coolant flow to prevent debris from settling in pockets in the heads, case, and heater core. the air conditioner can be cycled to keep all the seals wet with refrigerant oil. If the weather is really decent, you can even lower and move the car to exercise the steering and suspension.
I've had injectors get fouled from deposit buildup on the tips a couple of years, and I suspect this is from the long idle periods between starts in the storage season. I've spoken with Rich at Cruzin' Performance about this phenomenon, and I plan to experiment with fogging the intake plenum with a rust preventive or kerosene (diesel fuel) just before shutting down for the last time to try to prevent all the fuel from evaporating on the tips and the resultant deposit formation. Frankly, I'm getting tired of pulling the injectors every spring for cleaning on three cars.
Rich has not advocated this procedure, but he did say that it probably wouldn't cause any harm, and might actually help the situation. If it doesn't work, I've lost nothing since I'd be pulling the injectors again anyway. Hey, it's a theory - I'll be the guinea pig. So far, it's worked for the first season, and I'm keeping my fingers crossed for next spring.
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
Old Sep 1, 2001 | 07:39 PM
MartyMcFly's Avatar
Car: Z28
Thanks, Vader, as always your info is much appreciated.
I do have a few questions, though:
1. What do you mean by Ziploc?
2. What are your thoughts on waxing before storage?
3. You mentioned fouled up fuel injectors, are there any similar concerns with a Q-Jet?
Galaxie500XL
Oct 1, 2015 01:05 PM
Chevykid810
Sep 28, 2015 12:57 PM
Swede
Feb 21, 2006 08:36 PM
easySPEEDcamaro
26
Nov 20, 2002 05:46 PM
TomP
Oct 2, 2002 03:43 PM
